02-01-2012, 08:28 AM
#21
Vintage Kin
Fort Worth
a larger 28 footer that could weigh 8000+ lbs loaded
Certified three-pad weight scale is your friend, and is basic homework. Look up the CAT Scale Locator and weigh the vehicles separately and together, empty (solo) and loaded for travel.
245F is too high, so question the "gauge" itself before committing to anything expensive (see SCANGAUGE).
On any auto trans I would prefer a downstream aftermarket stacked-plate cooler (B&W Racing; thermostatic bypass) with a filter also installed (the pan "filter" is little more than a screen).
02-01-2012, 11:45 AM
#22
2012 25' Flying Cloud
Eureka
Originally Posted by ROBERT CROSS
Yes...it will have an up-graded cooler with the towing package. KNP option code listed on the sticker on the inside of the glove box door.
Beautiful. I checked the codes - bingo! Thanks Robert. One of these days I think I will copy all the codes and look them all up to see what I actually own!
02-01-2012, 01:04 PM
#23
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
RD
No problem...
You can ask your dealer to print out a GM VISS check for you to get the complete warranty service history, build sheet with all options.
You may even be able to get it online.
Vehicle Inquiry Service Summery
02-01-2012, 01:08 PM
#24
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
RD
No problem...
You can ask your dealer to print out a VISS check for you to get the complete warranty service history, build sheet with all options.
02-04-2012, 05:59 AM
#25
2019 27' Tommy Bahama
London
, Ontario
There are performance outfitters out there that add turbo's and supercharges to the 6.2 and have it turning out over 1000 HP so I don't think we are ever going to twist the block towing with one. All the 09's I have seen have had the 6 speed transmission. I did get confirmation that the 1/2 and 3/4 ton six speeds are identical.
Most of our customers with 6 speed transmissions have the 5.3 so there are no transmission heating issues at all. We traveled all through the hills in southern PA and northern west virgina this summer, my friend Blair tows his 34 with a 5.3 with the 6 speed and 3.08 gears, it was not as quick as the Mercedes diesel or the SHO but it certainly had no problem with the hills or temperature. Towing fuel economy has not changed much but he is picked up 5 MPG solo driving which is the majority of his use.
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
02-04-2012, 03:35 PM
#26
Oswego
OK, I guess the Brand Quality Manager for GM v8s is wrong. Never mind.
Unless the model identification number etched into the transmission case are IDENTICAL, they are not the same.
There are literally dozens of model/ID in each transmission SERIES designation (ie. 6L80E, 4T65E, etc....)
-Rich-
02-04-2012, 08:31 PM
#27
Lin
, Ne
02-04-2012, 10:04 PM
#28
Maniacal Engineer
Lopez Island
I fitted a B&M 70274 SuperCooler to our F250 - big difference in oil temps. I can recommend this unit, along w/ an Autometer full-sweep gage to keep track of the temp.
- Bart
02-05-2012, 12:44 AM
#29
1978 31' Excella 500
Genoa
, Nevada
Originally Posted by TRfour
GM recommends that the maximum transmission-fluid temperature (measured in the sump) for short durations shall be no greater than 285 degrees F. At 300 degrees F, research shows, metal parts inside the transmission begin to warp and distort, seals begin to melt, and fluid life is extremely short because of heavy oxidation.
Those are asphalt paving temperatures by the way. Not so good for transmission fluid or parts.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
02-05-2012, 06:18 AM
#30
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
B&m
- Bart
Very good unit..nice for us gyz up North too.... It won't "overcool" during the Winter month's. A feature not to be overlooked. T fluid must warm quickly.
