10-06-2016, 11:01 PM
#41
Black Diamond
Originally Posted by Maniac
if you dont mind what did you use for the thimble on the out side of the roof for the stove pipe i have a curved roof as well ? thanks
I used a Dektite round flashing. http://www.pipebootexpress.com/store...Gray-EPDM.html
Flexible to fit the curve of the roof. I should have trimmed it while on the roof. I trimmed it to fit snug while on the ground but it loosened a bit when fit to the roof line. Thus the high temp silicone. Working great now. Down the road I'll replace it and clean it up a bit. I used vulkem to seal it to the roof.
10-06-2016, 11:12 PM
#42
Black Diamond
Originally Posted by duncans
Beautiful trailer, very unique. The front lounge / ottoman looks like an indoor campfire!
If you don't mind answering, how many do you plan to house / sleep in your wonderful trailer?
I hope you had a great first time out.
Susan
I built the front lounge with 3/4 ply and select pine. There's a 1" x 3/4" lip on the street and curb sides which I lay 3/4 ply across. Allows for three adults comfortably. The rear bed sleeps two with room to spare roughly 50" x 81" with nightstand/headboard.
First trip was amazing. Glad I went with 5052 lightly polished for interior skins. It's fun to lay in bed and look down the trailer and see the fire light flickering on the polished ceiling. I've only had tents and a small popup to camp with up until I bought this sovereign.
10-07-2016, 10:01 PM
#43
1985 34' Sovereign
san diego
thanks for the reply Pygmypoacher installing my cubic grizz in my bus in a few weeks
10-07-2016, 10:03 PM
#44
Black Diamond
Very cool. Post pics here - would love to see your results.
10-19-2016, 11:11 PM
#45
1979 Argosy Minuet 6.7 Metre
Mayne Island
, British Columbia
Hey there, thanks for all the pics! Looks awesome!
we ordered a cubic woodstove (excited!) for our 79 argosy and also plan on having it exit out the curve. Wondering if you got silicone or regular dektite round flashing?
Also, looks like your stove pipe in the pic is larger than 3" diameter (maybe im imagining this). Did you surround it with heat shield pipe as well?
Last question, what did you use for your chimney exiting the trailer and rain cap?
Thanks!!
10-20-2016, 12:47 PM
#46
Black Diamond
Thanks!!
K.Cham, contact Nick (contact info above) he'll set you up properly. Thicker pipe is insulated and needed to keep flu hot and smoke hot to reduce/eliminate creosote buildup. I used Nick's insulated pipe and works great - slight adjustment to the base is needed to fit stove pipe top. Working great for me. 30° of this week and toasty inside.
10-28-2016, 11:39 PM
#47
Black Diamond
11-19-2016, 09:37 PM
#48
Black Diamond
Did you get your stove in? Would love to see pics of your install.
11-22-2016, 06:01 AM
#49
Airhead Team Member
1978 23' Safari
North Padre Island
Wow, fantastic job!
How long does a renovation like that take and how many people involved?
Thanks!
11-22-2016, 06:37 AM
#50
Black Diamond
Originally Posted by KeyWest
Wow, fantastic job!
Thanks!
Bought the trailer in November of 2015 so it's been a year to get it this far. It was just me. I did try to find someone to hire for the axle replacement but wound up doing it myself when shops didn't call me back. Turned out OK when the alignment shop said I was within a 1/4in side to side. I learned a lot of new skills during this project. Airforums was my number one source for information.
11-27-2016, 08:41 PM
#51
Black Diamond
11-28-2016, 03:18 PM
#52
Houston
Awesome work, there are quite a few ideas I might "borrow" for my own rebuild once I get to the interior portion.
On the stove, does the base come standard with the Grizzly? Looking on the website it looks like the unit comes with four legs or the floor mount pedestal.
Also do you have any past experience with Bus Kote or were you sold by testimony and literature? After reading from another bus forum I'm thinking of going the way Henry Solarflex but haven't committed one way or another.
Thanks!
11-28-2016, 03:50 PM
#53
Black Diamond
The base I used is their stainless fresh air intake (CB-2070-SS) that I plumbed to the bottom of the trailer. It's not provided with the cost of the stove.
I went with Bus Kote based on the ceramic particles in the coating, excellent reviews, available clear coat protection meant to work with the product and local school districts using it on their vehicles. Just one of many options.
11-28-2016, 04:06 PM
#54
2007 25' International CCD FB
Northridge
Is the fireplace removeable or permanent?
LilNomad
11-28-2016, 04:08 PM
#55
Black Diamond
LilNomad
It's legs are screwed through the intake grate to the counter top. Meant to be permanent but can be removed. Travels great.
11-28-2016, 11:19 PM
#56
Houston
Now that you say that, on a closer inspection of your photo I see that the grating is below the stove and not a face plate...
Thanks for the clarification!
12-01-2016, 12:01 PM
#57
Continents Collide
1985 32' Excella
Spring
How did you determine weight distribution when putting in new, custom furniture?
12-01-2016, 05:57 PM
#58
Black Diamond
I had removed and found far lighter alternatives for most of the heavy items in the trailer (propane fridge, AC unit, propane heater etc) so when it came to building the furniture I didn't skimp. I used 3/4in throughout. It's solid and didn't worry about the weight. Now with the power plant up near the tongue it is a bit tongue heavy but I offset that a little with full fresh water tank over the axles. Loaded the trailer weighs in at 5200lbs with the dual axles rated at 7000lbs.
12-01-2016, 07:48 PM
#59
1967 22' Safari
1966 24' Tradewind
Columbus
, Ohio
Wow!
This is really fantastic! I'm guessing that you get to use some design skills in your day job.
Your work looks incredibly well thought out and executed.
Love it and glad you are enjoying it, too.
12-01-2016, 09:47 PM
#60
Black Diamond
Thanks Mtmanor.
