10-15-2010, 04:25 PM
#21
Corona
Originally Posted by halimer
I forgot , it has 25K miles, no problems.
Have you checked the brakes yet?
10-16-2010, 04:55 PM
#22
2006 30' Classic
Milton
Dexter Axel Contact
Originally Posted by Jammer
Just had a seal failure on my nev-r-lube bearing. Apparently they're filled with oil. It's dripping out.
They are supposed to last longer than 2500 miles, aren't they?
I believe that the warranty is 5 yrs. or 100,000 miles, whichever comes first. They contain a grease, not an oil. Our 2006 Classic came with Nev-R-Lube bearings.
Talk to Rick Kapsa at Dexter. He is very knowledgable and helpful.
Rick Kapsa | Product Manager
Dexter Axle - Company Headquarters
rkapsa@dexteraxle.com ~ direct tel: (574) 296-7386
fax: (574) 295-1069 ~ main tel: (574) 295-7888 2900 Industrial Parkway East ~ Elkhart, Indiana 46516, USA Dexter | a Tomkins Company
Nick Meloy
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
11-09-2010, 08:25 PM
#23
2013 27' FB Classic
Clermont
So....what is the expected lifespan? Should the Nev-r-lube bearings be replaced every 5 years?
I just finished the 4th season with our AS. I am planning on replacing the tires and bearings in March 2012 after five years of use. Cheap insurance in my opinion.
Any comments?
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
11-10-2010, 07:54 AM
#24
2006 30' Classic
Milton
Expected Life on Nev-R-Lube Bearings
Any comments?
You don't state what the milage might be on your unit; however, if you are well below 100,00 miles, then you should not experience any bearing issues. If you have TPMS, then monitor the wheel temperatures as a proxy variable for potential bearing issues. If you detect one wheel that is not in line with the others, then investigate bearings as a potential cause.
F. A. Meloy
2006 30' Classic
11-10-2010, 11:40 AM
#25
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton
, Ontario
It could be just a bad seal / hub assembly. However if the hub assembly got excessively hot there might be the possibility that your brakes on that wheel could be sticking!!
You might want to check this also!!
11-10-2010, 03:06 PM
#26
Wise Elder
2010 30' Classic
South of the river
Report just in from the dealer who was looking at this.
Said that some leakage with temperature changes and use is not unusual with these and that inspection shows that the "oil reservoir" still has oil in it.
I'm supposed to watch it and be sure it does not continue to leak.
I'm not necessarily buying all this but that's what they say.
In response to the question upthread, my trailer has no more than a few thousand miles on it.
07-19-2011, 10:54 PM
#27
Wise Elder
2010 30' Classic
South of the river
No further signs of leaks so I'm guessing that the bearings were overfilled with grease when new.
07-20-2011, 05:40 AM
#28
Retired.
, At Large
Any comments?
They are designed for a 100,000 mile service life. So are the sealed wheel bearings on your family car and many light trucks, and they go hundreds of thousands of miles before replacement.
They are pretty much a "use it until it gives trouble" part. When you perform your Spring service, jack up one side of the trailer and spin the wheels, and try to move the wheel in and out top to bottom. If you don't feel a "rumble", minimal grease weeping, and there is no significant play, the bearings are good.
07-20-2011, 07:36 AM
#29
2013 27' FB Classic
Clermont
Overlander63 -- (Terry)
Thanks for the reply. I always monitor the wheel temperature when driving, and will take your advice and will give the wheels a "spin and pull" test.
Tom & Lori
05-20-2014, 11:28 AM
#30
Wise Elder
2010 30' Classic
South of the river
Looking back over some older threads, I can now update this report having myself personally disassembled the wheel that had this problem.
The leaking oil I saw was due to an unnecessarily generous application of assembly lubricant when the bearings were pressed into the hubs. It looks like the setup grease used when rebuilding engines, and it has a much lower melting point than chassis grease.
05-21-2014, 05:41 AM
#31
2008 30' Classic S/O
Dearborn
, Michigan
Thanks for the update.
My nevr-nevr's still going strong <knock-knock>
PS. shouldn't this thread be in the "Wheels, hubs, bearings" sub-forum?
04-24-2015, 01:14 PM
#32
2013 25' FB Flying Cloud
Tallahassee
Difficult Nev R Lube
Anyone have trouble pulling the drum off of the spindle with Nev R Lube's? I was checking my bearings and breaks the other day, the first three drums came off without a problem. The fourth was stuck on and took 20 min of shaking and pulling to get it loose. Once off every thing looked good. Going back on was just as difficult.
Anyone carry a spare drum and bearing?
04-24-2015, 01:57 PM
#33
Wise Elder
2010 30' Classic
South of the river
There are some other threads on this. I've pulled drums and haven't had them stick.
Given the cost, size, and weight of a bearing and drum assembly, and the relatively few reported failures, I don't carry a spare. Some of the boat trailer crowd complain about nev-r-lubes but that's an application where they're immersed. Overall I think they've proven to be fairly reliable.
04-24-2015, 02:11 PM
#34
Oswego
I carry one spare bearing....not a whole hub assembly. There's a shop with a press on every corner (ok, every other corner).
-Rich-
04-24-2015, 02:22 PM
#35
1999 34' Excella
Hillsboro
Rapping the drum with a 2x4 or deadblow hammer can break free the bond.
04-24-2015, 04:30 PM
#36
1974 Argosy 26
Morrill
, Nebraska
Did you back off the brake shoes before attempting to remove the drum?
04-24-2015, 06:50 PM
#37
Tallahassee
Yes, backed off the brakes. The bearing and spindle are very tight.
04-24-2015, 07:09 PM
#38
Lin
, Ne
Not likely but the bearing could of locked and the inner race welded itself to the spindle.
04-24-2015, 07:58 PM
#39
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
I carry a complete hub with bearing and a separate bearing. I realize it's overkill. Our last trip was over 8K miles so I justify it. Pulling a 27 FB with an F350 diesel, weight really isn't a concern.
04-25-2015, 04:25 PM
#40
Master of Universe
2008 25' Safari FB SE
Grand Junction
Last time I needed to find a guy with a press, the corner was 75 miles away in northern Minnesota.
I also had to order the bearings and make two trips to the nearest (but not near) town. They gave me the wrong washer and I had to find a guy with a reamer, but he was 1/2 a mile away. Why don't these things happen when you're home or in view of a wheel bearing emporium?
And I still don't carry spares with me. I figure it happened once to me and the next time will be someone else's trailer.
Gene
Gene
